HOW TO ADJUST FOG LIGHTS!
Ok I'm starting to see it. Will the fog light just pop out the front after I push those in? How do I know if they are in the right height location if I can't adjust them with them on the truck? Thanks man!
Lol, I am not sure, I have not adjusted them yet. I just know they are adjustable when I pulled them off to zip tie thee shit out of those LMZ LED bulbs LOL
I am guessing you adjust, both of them the same with a caliper, reinstall, test. over and over :dunno:
I really need to do mine, they might be blinding when I have a load in the truck bed, last time I got flashed when I have like 4 of those 18 litre water bottles filled in the back.
Ok cool. Maybe I can just pop the one out you circled out just enough to have the teeth out to spin it and pop back in? Would I use the screw driver to spin it?
I am sure screwing it in is aiming down, but I could be wrong. I have not adjusted mine yet at all. (screwing in as in you facing the back of the fog light housing.
Ya but the screw is on the bottom..
Screwing it in, pulling the bottom closer to the body of the truck, top is anchored, so it will point down.
SOLVED!!! Thanks guys. So for anyone else. This is how you do it. Really simple actually after you know what your doing lol. So the third screw/tab that's is for the adjustments is correct
http://www.gm-trucks.com/forums/uploads/monthly_04_2015/post-134831-0-94029600-1428371041.jpg
but you only have to pop that tab out. The other ones can stay. You can't pop all 3 out anyway and get the light housing out. You have to take off more stuff that didn't look easy to do that. But pop that tab out and grab a short Phillips head screw driver and screw IN. it goes for a good amount but be careful because for some reason when I needed one side a bit higher after it was not easy to unscrew. I don't know why but ya go in and then it's where you think you want it. Push on the outside of the housing on the bottom until the white tab snaps back. Then turn on your lights. Fog and head lights. Since my head lights are adjusted correct. And step back a ways and now you can move up and down til you see the "bright" part of the light. I made mine match my head lights so wen I see the bright part of my headlights I see the bright part of both fog lights. After you know how to do it. It can be done in 15 20 min depending on how many times you need to slide under and re adjust.
Did you tell the dealership!? I want to know their response lol
LOL, they cant say that, nothing is broken lol. Even some halogen headlights are designed to be adjustable, that is just plain dumb XD
Even if that is the case, they have to prove what is wrong to say warranty void
    BigJake
    BigJake
  • Who's Online   6 Members, 0 Anonymous, 464 Guests (See full list)
