I did it
jmhornz71
After 30 years of wanting one and finally having a wife that would let me I got my Harley. Its a black 03 1200 Sportster.
So now I owe the bank more money but its worth it. :banghead:  :smash:  :smash:  :smash:
Did you upgrade and get a-lot of chrome???
I love the song........ Her favorite color is chrome.........
Next you'll be asking the wife to let you go to Sturgis....
:jester:  Congrats on the bike
Oh WOW!!!  We need to see some pictures, please.  I have wanted a Harley for a LOOONNNGGG time...maybe someday.
Congrats.. :hail:
I'll try to get apicture but I have to figure out how to get it from the camera to this site. i'm not a genuis with this so it may take awhile.
Congrats.. :hail:
Sorry Batgirl. You ain't getting a Harley for your anniversary.
That was a nice try though.
Uncle who had 1 just passed away this weekend.  His gf also has a bike, not sure what she's doing with his at this point.  He definitely loved to ride.  Enjoy yours.
