2009 Seat rail covers
I had some sunglasses laying on my center seat and when I made a turn and they slid off, down between the seats.
They are laying on the left seat track of the passenger seat and I need to take the plastic cover that is on the inside side of the track off to get the sunglasses out.
How does that come out?
I am going to a clients today that is a body shop and I am going to see if they have one of those with a magnet on the end.
I have one at home, but won't be there until tonight, and could use the sunglasses today.
I thought I could pull that cover off and reach in and grab them.
They seem cool, can't think of a down side to putting them in, Maybe I'll get some too, nothing more of a pain the the butt than dropping something down there :)
Seems like a good concept. Can you post some pictures after install if you do get them. I would be interested in picking these up IF they fit well.
Sent from my crappy iPhone 6
using Tapatalk
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
