Mid Travel Suspension Install
I was wondering if I could get advise on what it would typically cost to install the following suspension upgrade on a 2014 Silverado. Here is what I have...
Fox 2.5 Coilovers for the front
Cognito UCAs with ball joints
3" differential drop kit
Fox 2.0 shocks for the rear
2" rear block
Quote also includes allignment
I'm hoping to have the dealership install the above items to have to highest odds of protecting my warranty but am worried that their quote may be a lot higher than other independent shops.
Thanks
Edit: Maybe a better way to look at this would be to ask... How may labor hours do you think this install would take?
Make sure you dont have aluminum control arms, if you do the only available uca's are uniball control arms as far as I can find. Also all this work is very easy to do yourself.
Thanks, my control arms are steel so I had a good selection to choose from.
I know I could easily do the work myself but was hoping I could get the dealership to do it for a reasonable rate to improve my odds of them sticking by the gm warranty if anything went wrong. I know gm will probably do what ever it takes to get out of the warranty but having a dealer fight for you helps a little, (I hope)
Also, thinking if for example one of the Fox Coilovers broke, the dealers certified mechanic would work with fox the get the problem fixed instead of me (backyard mechanic) trying to convince Fox I installed the product correctly and getting them to warranty there product. But I guess they would have to prove I installed them wrong, but it's still me who would be going round and round with them.
I guess that really depends on the dealership. I didn't buy my truck from the dealership I take it to and they've been great to me. I think you are mostly trying to safeguard yourself against the worst case scenario. Pretty hard to install a coil over wrong other than not torquing bolts to spec.
The plus side of having the dealer do it is that if something was to go wrong you would most likely get a loaner.
I kinda doubt the dealer will stand behind any labor themselves. In my experience if they don't usually install a lot of aftermarket stuff, they won't want to touch it. I think you'd be better off going through a good off road shop if your near one. Plus their going to know more than the dealer bout setting ride height correctly. The dealers probably gunna want to charge time in.
Good Points!
The dealer has a performance shop separate from the dealership that does a lot of lifts and performance mods which was one of the reasons I bought the truck from this particular dealership but your correct I think a dedicated offroad suspension shop would do a lot better job at setting things up correctly. Only problem is there isn't a suspension shop anywhere near where I live that I know of.
I guess I really don't have that much of a problem having the dealership do the work, I can always take it to a dedicated off road shop when I'm traveling to have ride hieght adjusted if needed. The big problem is what the dealership is quoting me to have the work done, seems really high but what do I know.
I had a reputable shop quote me $700 for installing my King shocks (all 4), UCAs, front and rear swaybars, & alignment.
Add your lift kit and rear blocks....I'd estimate $1200.
Thanks Spurshot, that helps a lot, the quote you received is really close to what I received from the dealership and the differences probably come down to labor rates. Total labor hours where quoted at 12.6 (Probably right out of the gm labor guide book, IDK) and the breakdown is as follows....,
Front coilovers 3.4 hours
Rear shocks and add lift blocks 2.0 hours
Front diff removal (adding spacers) and reinstall 3.6 hours
Upper control arms removal and reinstall 3.6 hours
Front end alignment $64.95
I think I probably just had sticker shock when I saw how many hours of labor the work required. I was guessing I could do the work my self in around 8 hrs but I was probably underestimating the job (wouldn't be the first time :). Looking at their quote it does appear some of the work is overlapping? Example: when replacing the UCAs it seems you are also doing at least half the job of replacing the coilovers. Also the labor hrs for the differential drop is for completely replacing the differential where as my understanding was all you need to do is loosen the bolts, drop the differential down and insert the spacers and then install the new bolts. I've never done a diff drop but I was thinking I could do it in an hour but once again I may be underestimating the job.
I wonder if anybody has ever successfully negotiated a better deal on labor hours with a gm dealership?
    C. Hart
    C. Hart
  • Who's Online   4 Members, 0 Anonymous, 592 Guests (See full list)
    • Thanks everyone for the help!   I'm going to stop into the scales one of these days and weigh my axels, for the time being, I am going to run Toyo's recommendations and also do a chalk test. I have a tire shop that's going to try their scanner to reprogram and set the the factory psi values lower, and if they can't I'm going to order a scanner and do it myself!
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
