wooohoooo
Jpshostr
Well, just plan on sticking around and getting the next status, what that is I don't remember. :(
Oh yeah, don't piss off LarryE either, he has ways to get back at ya I'm sure. :0
Any any particular reason why you capitalize each word in your posts?  Just curious.   ???
LOL!  I really didn't pay attention to his signature when I first read it but I'm going to laugh anyway, which will upset someone I'm sure.   :lookaround:
Jpshostr, I Do It Cause Its Diffrent :(
LarryE, I Hope I Didnt Offend You I Love Trucks Of All Types
You May Think Im BSing You But I Owned  A Lowered Truck(1993 Dodge Dakota Lowered 3" In The Front And 4" In The Rear, 318 V8 Ext. Cab, Short Box) The Truck Did Me Alot Of Good Made Me Lots Of Friends But Here In Michigan Its Just Not Senceable To Drive A Lowered Truck In The Winter And At The Time I Didnt Have Then GreenBacks To Buy A New Car.
Ever See A Lowrider Plow Snow? :D. I Also Pull A 6,000LB Race Trailer Unloaded. Loaded Its Like 8,000LBs Or More.
So Dont Think Im Dissin The Lowered Truck Crowd Cause When I Get The Money I Can You Can Bet Ill Have Another Lowered Truck.
I Just Thaught The Saying Was funny.
Carl
No, but I'm guessing you probably don't need a plow on the front of it.  The air dam hangs low enough on one of those lowriders to do the work!   :(
Sorry guys-I could'nt resist.
:D
Glad you're "Serious" now.
For some reason unbeknownst to me or Merv, I'm still just a member.  But that's OK, because I don't like to be "Serious" all the time and I'm much too young to be a "Senior".   :(
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
