Troy-Bilt Flex
I happened to be watching HGTV earlier and saw a commercial for the Troy-Bilt flex. It's basically a power unit that connects with various attachments such as a mower, snow blower, leaf blower, and pressure washer. I just thought it was an interesting concept, and I'm surprised there haven't been more companies coming out with something like this. Has anyone looked at one of these or purchased one? My yard gear is in pretty good shape, but this or something similar might be worth a look next time I need to replace something. Here's the link to their site.
http://www.troybilt.com/equipment/troybilt/flex
I've seen the same commercials. I have no experience with this product , but do love my Troy Bilt snowblower.
Sent from my iPhone
