zone aka flywheel brake cable for Poulan Pro push mower
&CDFiXER%
My trusty ol' Poulan Pro push mower appears to have the flywheel brake cable stretched.
Not surprising after @10 years and lots of mowing.
Bad news: I can not find my manual for a part number of the cable or the mower itself. Worse news: The deck cracked or rusted out in a spot 2 years ago and someone gave me a deck from a Crafstman mower, so no part number help there.
The cable is @ 59" long. Most of what I find are 53" or shorter.
I have been using combination of Google and Amazon to find what I can.
Anyone a mower parts guru or can point me to what I am missing?
I have looked up the cable for the donor Craftsman mower but it is @51" long.
Thanks!
Do you have a small engine shop near by? Typically they can pull the numbers off the engine and look it for parts. Also isn't Poulan Pro a Sears type brand? You may be able to go to your local Sears for some help as well.
I do have the manual and Briggs engine number (from the plate on the engine). But I think the cable is specific to the deck/handle combo.
Was trying to avoid the local repair shop because they have a 4 week lead time but I think I will take your suggestion and run the cable over there and see if they can help from that.
I took the cable all the way off to double check the length and noticed it was a little stiff. Used my oil extractor to draw some light cleaner through it until it was 100% free then followed with some Teflon cable lube. The brake is releasing much further now, so I am happy about that. Still going to try and get a replacement.
Thanks for the reply!
Well I learned something. These steel braid cables on mowers never stretch. They only break. At least according to the parts person at the local repair shop.
Wow. Why don't they use this stuff on e-brake cables, farm equipment, or any number of industrial stuff I worked on that stretched even slightly over time? Wouldn't take much to affect the geometry of the brake and switch.
FM.
    JohnRoy
    JohnRoy
  • Who's Online   5 Members, 0 Anonymous, 644 Guests (See full list)
    • Which one, the AT or AS?   Starfire is made by Cooper/Goodyear but at $85/tire I'd think I'd need to level-set my expectations that they may not even be round 😉 But you're saying they're decent?   I'm already into this thing $1506 in parts, fluids, etc. Totaled all my receipts today. $250 of that was replacing an EGR and MAP sensor that were probably fine, but I'm not going to return the parts since they've been installed. I'm cheap, but not that cheap. I use it, I keep it!   I may or may not make money if I sell the truck at this point, but, that wasn't really the point. And if I billed my time, I'd be hosed for real. My thought on the tires is I "might" put 1,000 miles on before selling it. I just don't want to put absolute junk on it, that doesn't do anyone any good. If the Solus solidly isn't junk, I'll definitely consider them.
    • I leave mine as is. I'm always a trip away from riding on unpaved roads. Dealer can clean it when they prep it after I trade it in for another new truck.
    • I have these on two vehicles and love them. Pepper is one of them 😉
    • 4WD. Far as I know it came stock with P's and not LT's. Definitely planning to put P's on it, but stock is a 109 XL load rating so I should probably stick within that guideline.   No rebates on anything I can see at the moment. Discount Tire is offering $50 off, but Pep Boys is very competitive on price, and also carries all the off-brand stuff. Les Schwab always wants an arm/leg, but they do good work.   It still has the original spare. Goodyear Wrangler RT/S, thing looks like a tractor tire LOL!! How times have changed.
    • 2020 Sierra 2500 HD (base model) gas engine 4wd.    All 4 windows roll down on their own. Happens somewhat randomly after stop and engine off - when engine turned off, when walking away from vehicle before or after locks activated. Pulled the window fuse F14 Instrument Panel Fuse Block Right; the driver's side still activates from driver's side door panel; passenger and back seat windows activate from local switches on their doors but not from driver's side group of switches. Power mirrors don't activate with fuse removed either (same fuse for both circuits). Problem not solved.    How can they even activate with fuse removed but they are all still opening and can control from each door?  When they open on their own, I can shut them from the switch in each door, but they don't stay closed.    Seems to be activated somehow with key fob; something bumping the key fob in my pocket or just handling - removed key fob and took it far enough away and now the windows stay closed. Replaced key fob batty just in case, no change.    Sounds like some kind of wiring short or maybe electronics. Dealer will first replace electronic control module without checking anything else and I anticipate problem will still exist since their troubleshooting skills are limited to "do whatever the computer says".  In any case, keyfob seems to be activating the circuitry.    Surely I'm not the only one with this issue, but I can't find anything related on the site. What do yall think?   JohnRoy
