Help Identifying a Leak
I noticed a greasy spot while changing my oil. I need help identifying the part. Pretty sure its the power steering but figured I would ask the experts.
I circled the spot in the pic above and labeled the front passenger tire to help orient you.
Here are the other pictures I took.
2
3
4
5
6
I haven't noticed any spots on the ground. No unusual behavior or sounds. I checked the power steering fluid and it was a touch low.
So whats the part? Do you think the dealer or extended (non-GM) warranty would blame my Rough Country level, or the slightly larger wheels/tires? How hard is it to replace?
Thanks!
That's your power steering rack and pinion. If it's not dropping fluid on the ground I wouldn't stress it. Keep an eye on fluid levels and drive it till she breaks. Also keep in mind this is at the bottom of your truck so it could be coming down from something else above. Kinda hard to tell in the pics. All in all you said it's not dripping so I would worry.
I looked around, all the way up and didnt see any other spot that looked like it was leaking. I'll do like you said and keep an eye on it. Thanks for the help.
It's something thats not supposed to leak so if you have any kind of warranty get it looked at before the seal blows out. If it's on your dime, live with it.
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   1 Member, 0 Anonymous, 550 Guests (See full list)
