'91 GMC c1500 popping noise in dash
Howdy y'all,
Brew here, I have a pretty unique problem with my truck. She runs like a champ and does what she supposed to. But I do have what I think is an electrical problem during startup and shut down.
During startup,
After turning her over an firing her up, the passenger side of the dash makes a popping noise for about 10-20 seconds (2 pops a second)
After Shut down,
The same thing happens, same popping noise for around the same amount of time
Now I am an electrician in the military, so I plan on troubleshooting this myself by shooting some wires after pulling some things off. I was hoping y'all have heard of this problem or experienced it yourself so I would have an advantage as to what I need to pay attention to after yanking her apart.
Soon I will attach a video of the truck startup and shut down after being driven a bit.
Any Ideas will help, she's my first truck. 260k miles strong. Last two known owners seemed very neglectful of this issue and the truck as a whole.
Thanks again y'all
BR3W
Well that is definitely interesting. I'm running components through my head that are located on that side of the truck. There's some vacuum lines for climate control and some control modules. I believe the control modules are for hazard lights and blinkers, but this was true on an older blazer. Your truck could be different.
Sounds like your fairly certain this is an electrical issue, but I think you should still stick your head down there and watch the actuators. The A.C. evaporator is also over there and could be doing something funny. But you're able to hear it, not me and that's probably the best info for diagnosis.
Yea I was starting to think it may be an actuator of some sort as well. I'm thinkin for the blower that works with the cabin heating. I have been so caught up with goin out shootin lately I haven't gotten around to checking it out.
I do appreciate your help though, I will put a video up of the sound so you can hear it like I do.
thanks again,
BREW
It's the actuator for the cabin air. Under the passenger floorboard , very common thing to go out. I just reached under and unplugged mine. Left it closed so my air just recirculates.
Howdy there,
Sounds like yall are pretty set on what it is, I did take a video of the noise it is nearly exactly the same as ol' boy's video ^ only difference is its a lot slower and lasts about half a minute. I will check it out tomorrow morning and get back to this an tell yall how it went.
I'll thank yall again for the advice
Also I am thinkin bout buying a '73 gmc crew cab 4x4 lifted bout 6" with mud tires. If I remember right its a new motor with less than 40k miles. is there anything I should look for specifically on that model? or is that a pretty good gen gmc?
BREW
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   2 Members, 0 Anonymous, 1,810 Guests (See full list)
