GMTC & FSC Declare Truce!
Josh
Mark and I have come together and decided that we are going to put everything to a stop.  All the nonsense that has been going on is over!  I think we all realised that it is pointless for this behavior to continue and it would be best for everyone if we made a major deal out of putting an end to it.
From now on Mark and I will be strict on those who try to start stuff between these sites.  Any swearing, rude behavior, or slandering in general will be considered just cause to ban you.
Thanks everyone for you understanding and I really think that this is the best thing for everyone because the fighting between us was getting just plain old.
Here is the other half of this post, found on FSCFSC & GMTC declare truce
Hummm Well If I Would Get Some Pictures Of My Truck Would U Be Willing To Make Me One With Both FSC and GMTC On Them Like Yours?
Carl
Carl
Sure, when you get the pics post it in the Digital Dreams section of FSC, we will fix ya right upsmiley_beertoast.gif
Thanks Alot Josh  :(
Btw You Have A Baddddddddddddddddddddddd Truck
Some Day Mine Will Site As High As Yours :D
I Will Post The Pics Some Time In The Next Few Days
Carl
Thanks Alot Josh  :D
Carl
Thanks!  Still have alot of things to do with it, but I'm happy so far:p  Post those pics soon, we'll even give you that lift and 35's so you can see what it will look like :(
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
