Suspension
I recently bought a 2015 Silverado and today decided to look under it and it has plastic sway bar links that look twisted and almost broken already... Anyone else have this issue?
I'll take pictures when it drys up
Hey JCJ,
I'm sorry to hear you're experiencing this and I understand how concerning this is with such a new vehicle. I would be more than happy to look into this for you and dig a bit deeper to see what might be going on. Could you please send me your VIN, current mileage, preferred dealership and contact information? I can certainly reach out to your dealership to have their service department take a look. Thank you and I look forward to hearing from you.
Anisha T.
Chevrolet Customer Care
Thank you and I have already had it taken care of, it was the cover on it that was twisted and cracked so nothing structural just looked like it was.
