Private offer help
Need some help, I have read through everyone's advice on how to try and get a private cash offer pop up with no luck. I tried chrome incognito window, Mozilla, and ie clearing cookies after any pop ups.
Does it matter what vehicle you are searching for when trying to get a pop up or can you click on any vehicle then once the pop up comes up change the vehicle to what I want to buy?
My ordered truck is due this coming week or the next. Also I have been clicking on 2500 Denali and wondering if they usually don't give them out for denalis. Anyways if anyone has any additional advice I can do or if someone by chance gets one that could pass my way that would be even better. Thanks
I got a private offer for $1500 off a Sierra slt or Denali a week ago. I was surprised, never saw one for a Sierra before. I was searching the inventory in my area for Denalis when it came up. I picked up my truck 5 weeks ago, so I didn't use it. I was curious what Denalis sold in my area since I picked my truck up.
What browser were you using? Also how long was it good for, did it last till end of month or give you 30 days to use? Thanks
I got it using safari on my iPad. It is good until 5/31/2015. Looks like I got the offer on the 4th of May, so it was two weeks ago.
  • 2 months later...
Were you able to get a Private Offer to come up? Better question is were you able to use it with an ordered vehicle? Fine print says "vehicle in stock" so wasn't sure if ordered vehicles counted...
Yes got the $1500 pop up and they took it no problems with my ordered truck.
I got mine by building the truck then went into the screen where you would locate the vehicle. Did that several times in google chrome clearing cookies and history.
Also if you have a farm bureau insurance near you just sign up, cost if I remember $60 then wait 30 days and you get another $500.
I bought my truck at Laura gmc and they took both rebates totaling $2000 on top of the deal they made me. I got the rebates 1 week before I picked up the truck and the deal was made well before that. Good luck
I got mine off of the chevy site while I was building my truck. This offer can't be combined with the USAA $750 DISCOUNT.
Got mine after building my truck and checking inventories several times also. Was using IE
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
