08 GMC sierra vortec max
Hey guys I'm new to this and I got a 2008 GMC sierra vortec max.... I got it dyno'd and my numbers are 292 HP and 306 tq.... I'm not sure if that's low but I have 35 inch tires and 20 inch rims with. A volant intake and magnaflow exhaust
I think I posted in the wrong area lol. I was wondering what else can I do to get more HP without adding a turbo or supercharge. I got a custom tune but it had no HP increase just performance I think I need a different shop.
Different dynos will show different numbers, they are all different.
Not exactly sure the dyno type but I had my my 2008 V-Max dyno'd at our race engine builders shop. My stock tune numbers were 342hp & 339tq. with the GMPP (Borla) exhaust and GMPP CAI it went to
After his custom tune running 91 octane it is at 371hp/363tq., that was the best run. If I can find my paperwork I'll post it. Very happy with that truck. Plan ob having my 5.3 dyno'd some time this summer.
Just remember, the dyno numbers depend on type of dyno from what he said. I don't know which type he has but I know it's on the paperwork if I can find it.
Your best gains will be from a custom tune.
Sent from my crappy iPhone 6
using Tapatalk
What kind of dyno where you on? Different types of dyno's will yield a little bit different numbers. Plus air and engine temperature matter as well.
Is your truck lifted? This shop supposedly tuned my PCM while it was on the dyno but I had no increase in power just performance. If I knew how to post pics I'd show my sheet
My truck has a front leveling kit and 3" rear blocks in place of the factory blocks. Also factory size tires, cooper discoverer at3 E rated LT's on 17" wheels.
If your truck was tuned, your sheet will show improvement over stock, or at least it should.....Going to look through all of my vehicle paperwork tomorrow, hopefully I can find my dyno information to post.
Do you have AFM tuned out?
Torque Management?
Factory tires/wheels?
What grade of fuel?
I wish I could give you more specific information about the dyno but I just don't know:
using Tapatalk
I have 20" rims with 35" tires, I asked about the tq management he said he adjusted it and AFM also. But my dyno sheet shows 292 HP before and 292 after. I'm not an expert on the sheet but my performance looks steady after not up and down like before. It was just a roller dyno not sure the correct terminology for it.
    Mistycool
    Mistycool
  • Who's Online   5 Members, 0 Anonymous, 1,677 Guests (See full list)
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
