Led bed lights on a budget.
$35 Amazon led lights. 8 total with plenty of wire.
Free connector and free cargo light switch.
Stuck the led lights in the open area underneath the bed rails.
Made sure the wires were snug with no slack in between.
Punched out What looks like pin1 to me is 12v and pin6 is the ground.
Shoved in my wires and siliconed around them.
When u hit the cargo light switch it supply wires to the pins.
Took me all of 2 hours of figuring out wires.
Now I can see my gear at nite when I go fishing.
I figured I'd post pics and a few tips to help out since i have taken many pointers from the site.
Cool idea. They just don't seem as bright as the factory ones. For the price it's pretty cool. But are there any other options on bulb wattage or output?
  • 2 months later...
Reviving this old thread to say thanks for the idea.
I also used the factory plug drilled through with female connectors I had around from an old harness.
I only needed lights under the front portion of my bed that stays dark under my Extang Solidfold first panel when folded forward since the cargo light doesn't reach.
I used these led strips that come pre wired, and the 60cm spans the bed side between the openings perfectly.
http://www.ebay.com/itm/121196703416
Note the sticky back on these did not stay on the factory sprayed bed very well so I used some construction adhesive to make sure they stay on.
I hear silicone adhesive will work as well.
I'm all set and for less than 10 bucks, thanks Chico!
  • 3 months later...
I bought similar lights from Amazon for like 35.00 There are 8 lights and I installed the switch in one of the rubber plugs on the right side. I ran a dedicated hot and ground from the battery to the bed. Took me about 90 minutes while also looming the wires and running the wires etc. Pics below.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 500 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
