Tire Programmer - options
I was trying to search but for some reason it won't let me... Anyway, what are you guy's using to reprogram yours trucks so you don't have make a trip to the Dealer every time?
Our local WalMart auto center will set them free, I'm not sure if that is a local thing or nation wide.
you can also reprogram your tire without any tool
just put your truck in learn mode for tire
then follow the sequence of light ( left front, right front, right rear and left rear)
instead activating with a tool , just let air get out from tire until the horn sound, do the same thing on every others tires until 2 horn chirp sound
then put back air in tires
This is incorrect, that only works up to 2013 vehicles. As of 2014 GM now requires you to use the tire tool to sync the TPMS sensors. You can put the system in learn mode but you have to use the tool now.
yeah you're right .....just checked
i didn'T notice that yet, i've learn something new today ;)
    C. Hart
    C. Hart
  • Who's Online   1 Member, 0 Anonymous, 431 Guests (See full list)
