Edge cts 2 stock speedo change?
Quick simple question and can't find the answer anywhere and the holiday everyone is closed. Does the edge cts 2 change the stock speedo in a 2015 1500 Silverado after I enter my 35" tire size? Or is the correct speed only on the edge screen? Thanks guys
