Taillight led bulb information help
Hey guys iv been doing tons of reading im trying to do all my lights either hid or led... Now my question is i know for the brake light bulbs are a 7444 from what iv found on the forum 1f6f00f42afacbd9b817e52340702148.jpg
Then I checked on the cross reference sheet and I didn't see anything that matched the 7444 bulb number e1172559f53ced458a264d84b6083050.jpg
Here are some number for Phillips led brake light bulbs that are local to me will any of these work on our trucks that won't give me some type of stupid code or error or is there something better that I can order online that will work to Mach all the other lighting im adding 136920a042bef7cd93686b716315c3f8.jpg
Thanks for reading and trying to help guys
Sent from my SM-G900W8 using Tapatalk
    • *Your
