Weight Distributing Hitch setup with leveling kit!???
Im reading about the proper set up of a WD hitch but not seeing much about when used in conjunction with a front leveling kit. What I've read is, when properly set up, the front should be the same hight as when unloaded and the rear squat no more than 1 1/2 ". So, does a front suspension leveling kit have any effect on this set up? specs
2011 Silverado crew cab
1500 5.3, 3.43 gear, 6 speed, tow package
front leveled 3"
towing loaded weight shy of 6000lbs 29' ultra lite TT with husky WD hitch
Thanks Gents
Shawn
On my last truck I had a leveling kit and I intentionally set the front end about a 1/2" lower than the rear. That way when I did hook on to my trailer it left my truck level.
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
