Trim Removal
Anyone know how to safely remove chrome trim pieces below window on a 2015 silverado? My new truck has them and HATE chrome. Also, anyone know part numbers for black ones? I have the ones below, but not sure if they are correct?
LF pt#20964064
RF pt#20964063
RR pt#20963927
LR pt#20963928
its easy first roll the window all the way down. on the front doors there is a small screw on the end of the trim on the rear doors it is towards the front of the door under the weather stripping. When the windows down you can see inside the door and you will see white tabs at the base of the trim. Use a long flat blade screw driver or a right angled pick like i did. I started toward the front of the doors, gently pull the clip in towards the truck and pull upwards on the trim I did that on the first couple clips and the ones toward the back of the door unclipped by pulling up on the trim. To put the black trim in just slide it down and you will hear the clips snap in. All is left is to put the screw back in. First door took a little bit to get the hang of it but the other 3 only took a few moments each.
