Cooled Seats?
My cooled seats are a life saver here in Texas. Mine was parked out in the sun all day the past three days and each day while walking out to the truck I remote started and by the time I got in the truck the seats were significantly cooler.
It's not like having an ice pack on your back, but ANY air circulation on your back and butt helps when you are warm natured. At the end of my day any breeze between my legs is a god send, and I'm not a 'large' guy.
If A/C seats are an option on any vehicle I get going forward I'll be getting it.
I can also agree with Go Ordnance, if I forget mine are on during a longer drive I'll get a chill.
You think so Tjay? I never thought of that. Anyone done or attempted it and have an experience. Would be nice to know before I spend that $$
Also the good reviews on them just makes me want them more :C
The BCM pretty controls a lot of the body systems now, so that is what makes it challenging since the dealers cant program the BCM with anything other than the firmware calibration that GM has on file for that VIN.
I would imagine that the functioning portion of the cooled seats are controlled by wiring. Sure there would be a way, if he got the seats... to connect said wiring to a manually controlled switch. You might not get the full control of the high/med/low like those of us with the factory option, but you should be able to make it work. Just depends on how determined you are. Definitely won't be a plug and play kind of upgrade.
I believe they are much more complicated than a switch will do,
The body control module (BCM) monitors the heated cooled seat switches through LIN bus message inputs and determines the heated cooled seat operating modes and temperature levels. Each heated cooled seat is capable of operating in 3 modes with 3 temperature levels. The BCM controls the operating mode of the driver and passenger seats through separate pulse width modulation (PWM) signal circuits. Each mode and temperature level is commanded by a different Duty Cycle. The PWM signal circuits are referenced from battery voltage by the blower assemblies and pulsed low by the BCM.
Now that's a good answer. I'm gonna have to ask GM about it now.
Ahh... you and your fancy science... just have to prove me wrong with facts and actual numbers. :-)
I'd still be tempted to try to find the right wire to put power on to make the fan blow. But it sounds like he'd be better off looking for an aftermarket add-on, as someone else already said. :cheers:
It very much plug and play with a couple minor exceptions.
You need new wiring OEM harnesses that are for oem AC/heated for driver and passenger seats (main bottom harness AND back harnesses) and you need to add the new oem button module in dash (the in dash wire harness will connect to same button module as your heated seats button). Then you need to add missing LIN bus wiring (i think thats what its called) from bcm module to the female connecter that main big yellow seat connecter plugs into new. (The AC/heated seats main wire harness is almost identical to heated seats only harness with a couple extra pins inside that connect for the cooled seat function and the blower connecter). You also need to switch to the oem cooled seat foam, add oem blowers that go into new AC/heated seats foam and add this plastic air bag that connect to blowers that lays under the leather. The new OEM Ac/heated seat foam comes with the heated pad already attached to it (same heated pad as the heated only seats, AC/heated seats use blowers for cool air ONLY) Then when thats all done, you need to have a VCI update to your VIN done to tell the BCM you have the oem ac/heated seat option added to your vin so it can turn the seats on (which isn't easy as you need a dealer to have it done for you after they get GM to approve it). And waiting for the OEM harnesses may take a while as they are still being used on produced trucks.. Oh and dont forget you need perforated leather.
There's the process, don't ask me how I know all of it. :smash::thumbs:
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
