Question About Gibson Exhaust
Waffen06
Found a good deal on a Gibson exhaust for my 2015 double cab, problem is its the exhaust for a crew cab with a 6.5' bed, now it seems with every other brand out there you just cut down the mid pipe to make it fit the shorter truck. Gibson has a separate part number for every length of truck, I called Gibson and they said there is a slightly different bend in the mid pipe that you couldn't just cut it down. Anyone have a Gibson exhaust on theirs and is there a bend in the mid pipe? Does it hook up to the factory ball socket? Anyone see a reason why the bend would be different?
I can't imagine there not being a section you couldn't cut enough out of
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
