Mounting LED Lights
Hello,
I'm new to this forum and was hoping you guys could help me out.
I have a 2015 Silverado 1500 LT I'm looking to install four Rigid Industries LED D2 Driving Lights behind the grill. I know RI makes mounting brackets to do this for their LED light bars, but I was wondering if there is anything on the market for spot lights like these? It doesn't have to be RI branded.
Attached is a picture of the truck. Ignore the lights above the license plate; looks like crap hence this project.
Thanks for your help!
