Upgrading to OEM projectors
So I'm looking to get a set of OEM, or OEM style projectors to replace the headlights on my LT.
I found this website that has some that are blacked out for $249, I'm thinking i could swap out the black trim for the chrome trim off my stock headlights. Anyone have these?
I Like the Anzo lights too, but I'm not really wanting to spend over $500 on headlights at this point in time.
http://www.protuninglab.com/20chsi15253510.html
