+New wheels and tires
2014 Chevy Silverado LTZ 4x4 Rough Country 2" front, Readylift 2.25" rear, Tuff T13 20x9 +15, Falken Wildpeak AT 305/55/20. No rubbing so far
https://www.customwheeloffset.com/wheel-offset-gallery/25647/wheel-offset-2014-chevrolet-silverado-1500-hellaflush-leveling-kit-custom-rims
Looks nice. I can't stand the word "Hellaflush".
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
