Abs problems
Does my 93 k1500 suburban 4x4 abs system use a fuse or a relay. My brakes went out, and a coworker suggested replacing the abs fuse/relay(whichever the case me be) before replacing the booster. The abs light has been on since I bought the truck in 2010. I didn't think anything about it,but recently it has been using fluid but there is no evidence to explain where the fluid is going. And really recently the brakes have been spongy and today the abs light went off and the brakes failed and now won't work at all. Any ideas?
Crawl under the truck and look at the drivers side bottom of the frame for an area wet with brake fluid, I'll about guarantee you've got a rusty brake line that is now leaking. These years are notorious for the lines rusting out. The ABS uses a large fuse located under the hood in the black box with the cover on it, I believe it's a yellow 60 amp. If the brake line is leaking most likely both the brake light and ABS will be lit up.
Also could be master cylinder leaking back into the booster. The way that I check a master cylinder. I have some plugs that I made up. I remove the brake lines from the master cylinder and screw the plugs in. If the master is leaking past the seals you will lose the pedal. If it holds then it is not the master. Then I will replace one line at a time and test for a pedal. The line that you loose the pedal on will be the section that you start to inspect for leaks. But this method is not necessary if you have an obvious leak.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
