2015 GMC Sierra Chrome Mirror Cap Removal Help!
GMC207
I ordered some black painted mirror caps and I cant for the life of me get the chrome ones off. I dont want to crack or break anything. Anyone have any pointers? I googled and found 2013 videos but nothing really on the 2014-2015s.
Installation Instruction Part Number
Firmly grasp mirror housing cover (1) and lift upwards then outwards from the mirror to release the retainers.
  1. Align the new chrome mirror housing cover (1) with the base of the outside mirror housing assembly, push forward until the housing cover is fully seated into the outside rearview mirror base retaining tabs.
    Note: Inspect the outside rearview mirror for proper operation.
Ya I have firmly grasped and lifted up, this is not enough info on removing them in my opinion. It came with a sheet that said this same thing, but thats all it says.
I don't know how other people did but I did hear there's a tool to take it off but me I lifted up on the top and then pulled it forward. I did break the plastic clips on the cover but after I dipped it I put it back on with two sided tape and that's been about 3 weeks ago and it's fine
Were you able to get them off without breaking the tabs? I just got mine today, came with the same instructions...
Nope. The bottom tabs all broke and I was very careful. What I did was slide a credit card starting on the outer corner and slid it so it was under where those 2 tabs are, then got a butter knife in and used it to pop the tabs out. It came off easy at this point, didn't scratch or gouge anything, but the tabs are junk. I don't know how they could possibly come off without breaking them unless you could go from the inside behind the glass.
Thanks GMC207. I'd like to save the originals if possible but mine were the black textured caps and I'm putting the painted ones on. Were the new caps easy to put on?
At this point, I'll not worry about screwing up the old ones...just don't wanna damage the new ones...
Ya the new ones went on no problem. Nothing broke. They pop on very easy.
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 877 Guests (See full list)
