Wheels for Tungsten Gray '15
eznonby
Guys I need opinions on a wheel for my Tungsten Gray Silverado...I believe I want to go all chrome since the truck already has chrome accents on it. I'm not looking for name brands, I'm looking for actual opinions on wheels....help me out????
This is what I decided on. The grays are not an exact match, but with the black ring separating them, its hard to notice. Cool thing about this color rig, is that I think it looks great with chrome or black. You cant go wrong, so just pick something that YOU like.
I like the anthracite grey or dark tint colored wheels from fuel. The think they go well with the tungsten/iridium metallic trucks. Cant go wrong with black either. Heres my truck.
I'd like to see more of your combo. A couple different angles, sunlight perhaps. Thanks. Looks sharp.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
