New Smoker
BenzTruck300!
I like Masterbuilt's 40 inch electric model. Window is not a selling point. It get gets covered in smoke and everything else.
The purists say you can taste the propane. I never could.
I have been smoking with a Komado, a heavy large offset, and even with my gas grill, for about a dozen years. I don't think it makes a lot of difference what you use so much as how you use it.
With propane you taste the meat not the heat
I have a couple friends who like their pellet smokers. A little more money but they sure swear by them. One has a Treager and one has a Greenmountain. I haven't used either but have tried the meat from both. All I know is that the end result was pretty darn good.
Mike
  • 1 month later...
A friend of mine made his own out of wood a few years ago. Imagine a tall skinny dog house, hard to believe wood doesn't burn, but it works awesome. I will try and get you photos next time I'm over at his house
  • 3 months later...
I'm probably real late on this one and maybe you've already gotten a smoker....but,
I love my propane landmann widebody smoker!!
Sent from my Note 4
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
