1997 Jimmy Questions
I recently bought a 1997 GMC Jimmy. Its actually a super clean rig. The glove compartment had service records going back nearly to when it was new. It has around 129,000 original miles and has only had a couple different owners.... it needs plenty of TLC and the first time I attempted any sort of automotive projects was roughly 2 years ago (I actually went to college for computer science).
So, attempting to work this out on my own is rough.... you can't really find exactly what you're looking for on Google... So, I have a series of possibly stupid questions...
1. TRANSMISSION: I'm fairly positive that the 3-4 clutch is toast. It won't shift out of 2nd... I have a parts car with a (allegedly) good motor and tranny. Its a 96 Jimmy (same everything 4wd,auto) and I've had a lot of responses on a craigslist ad for a tranny. So,
Is there any way to know if a tranny will work before installing it... other than fluid look and smell?
Is there any way to tell if a transmission has been rebuilt? And what mods were installed?
Is there a newer, better transmission that I could semi-easily install that wouldn't have as many issues as the 4L60E?
BRAKE BOOSTER: how much should I pay for a used one? Or should I try to rebuild it. Its not the check valve or the hose, I think its the gasket...
KEYLESS ENTRY: the steering cover was missing when I bought it (I'm assuming they thought the tranny issues were a faulty ignition switch), so I can't tell, but did the SLE model come stock with a transponder chip in the key and keyless entry?
Like I said, this is my project.... and my daily driver (I put over 2000 miles a month on work vehicles) so I'm sure other questions will pop up... I'll take pics if I need to also.
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
