New wheels, different tires sizes
HtxChapter
I recently bought a 2015 Silverado LS regular cab with 255/70/17 tires and was looking to change that with some 22" aftermarket rims with 285/45/22 tires. By doing that can that mess up my transmission, gears, motor, or anything at all?
Extra weight and size will create added wear on everything but that is not a huge jump in overall diameter. I say you are good to go.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
