US Flag painted on GMC (like Bowtie)
CalDirt
I'm the proud new owner of a '15 GMC Dmax and I wanted to get a custom-painted GMC emblem like I had on my '04 Chevy. Back around 2005, there was a guy on D/P who was doing this (by hand!) and I had him do a set for me (as you can see below) that I absolutely loved. This is one of the things I'm going to miss most about my old Chevy but it's time to upgrade.
I found another user who had this done on his GMC logo (see below) and it's almost exactly what I'm looking for. He gave me his source but that guy has gone dark - doesn't respond to anything.
So does anyone here have a good, reliable, professional, cost-effective source for doing this? I'm not looking for decals or anything second rate. I want to hire someone who knows what they're doing with an airbrush to do it right, as you can see below.
Thank you in advance
No need to waste your money to pay someone to air brush. Your best bet would be to find a local hydrographics guy. You could get the bowtie dipped for $20 to $30.
Sent from my SM-G900P using Tapatalk
  • 4 months later...
  • 9 months later...
Not sure if you still need this or not. I had hand painted Chevy Bow ties done for my new Chevy 2500hd. DRgraphix on Etsy.com is a true artist. I'm certain he can do your work. I have lots of photos but all too large to load here.
Oldcsm
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 630 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
