Nitto Terra Grappler G2 305-55-20XL
hotrodz37
Nice! I'm sure they will look even better once they are mounted!
I'm debating picking these up as well. Either this size or in 275/60. Are you mounting them on the stock wheels?
I have 275-60-20 toyo at2's on the stock wheels now and they are too skinny for me. I am putting these on a set of aftermarket wheels (below). Discount tire direct is running a special on eBay right now for the tires if you're looking to purchase soon!
Don't forget to post pics once you're all set up!
What's the offset on the wheels? 20x9?
Yeah, they're 20x9 0 offset. Might rub, if so depending on how bad I have another set of wheels picked out with +18 offset
Little late but i picked up the duratracs after a ton of research a86bc921c3c89bfce2461ef219f564bc.jpg6f4e56efc0802384d21c58b359c91fd4.jpg
Sent from my SM-G920V using Tapatalk
Well did you get them mounted up? Let's see some pics!
  • 8 months later...
Does anyone have input about the snow performance of the TerraGrappers? This is one of the tires I'm looking at because they come in odd sizes 275/65-20. I am leaning towards the BFG KO2's.. Because they are a tried and true design but the Nitto tire is a little more than half the cost. I haven't seen any comparisons to each others.
Nope, not really any louder then stock
    bellssn690
    bellssn690
  • Who's Online   3 Members, 1 Anonymous, 886 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
