Man bites dog
Wingnut
:flag:  I belive around here that that kind of stuff is the same as if it were one of the human police officers he was bitting.
The canine units are considered police officers by law.  As a result, not only could they give him a cruelty towards animals charge, they could charge him with assulting a police officer.
"I don't really remember," he said. "I was pretty drunk."
At least he was honest. :crackup:
And those dogs are a good chunk of change.  We had the scare of our life a few months back as 1 of our handlers was rolling an apple down the back hill behind the station and the dog ran after it right as a car was coming across the aisle.  It got his paw in the wheelcover a bit, but no permanent serious damage.  1 second or 2 either way and it wouldn't have been pretty.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
