Anyone else been watching?
Elwood
Maybe this should be in Motorsports, if so go ahead and move it.
NASCAR TV on the SPEED CHANNEL is pretty cool.  From 3p.m.-12am each day they turn the channel into NASCAR TV.  And they've been showing some old races, and profiles on drivers and crew chiefs and other people.  Lots of updates on Daytona.  It's pretty dang cool.   :thumbs:
I hope that isn't permanent. The variety of shows the had made it interesting, I especially liked those nutcases racing through the mountains and sometimes off the mountain.
My inderstanding is that it is gonna be on for a while if not permanent, but I think it's only gonna be through the week.  And it will be interrupted for actual races of other series that they have covered in the past.  But I'm not sure.  Their new website isn't up and running yet, so I can't find out until then.
