Move Bumpers
SkippyG4
Good lord those things are hideous. They don't go with any of the lines of any of the trucks listed on their site. And being DIY, I could only imagine how long they last......
My $.02, look for something better.
When they say kit, does that mean they ship you the steel and you weld it?
Looks like a lot of steel but not much structure honestly. Makes mine look low profile.
it includes the brackets to attach to the frame and all welding of pieces is done by the purchaser. they didn't have any pictures of one on a 2014 but I did see a 2016 with a full grillguard via Instagram.
here is a youtube of guy welding one up.
