GMC buyback usage fee
Tattooo
Go through the vibration thread. There are some who had nothing and some who had a fee
Sent from my SM-G920V using Tapatalk
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
