BlackBear Performance Custom Tune Appointment Near Houston, 11/14/14,
Justin can set you up with multiple tunes...I have an 87/89 octane and a high octane (E85tune). YOu will not regret tuning...It was a night and day difference as far as performance on my truck..... I say do it.
Titties...just noticed the Houston event is sold out. I do have an Intune right now, but always been interested in Blackbear. It sucks because I live in the Woodlands
I had my 2014 6.2 tuned a month or so after I got it. Maybe had 1,200 miles on it. That was in May of 2014. It now has around 18,000 miles on it. No problems whatsoever. It was not tuned by BB but I will tell you it was the best money I have spent on my truck thus far. I had the cylinder deactivation disabled, the engine and transmission tuned using a local reputable guy that uses HP tuners. I would not consider going back to stock even if GM threatened to void my warranty. My dealer knows it has been done and has no problems with it. They truck shifts better, has seamless power and uses 0 oil. This is how it should have been done from the factory. By the way, the tune totally eliminated any throttle lag I experienced before. I would do it again if it cost 5 times what I paid. Just my .02 cents.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,357 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
