Instument cluster noise
I have grinding sort of noise coming from behind the instrument cluster. Do the new Silverados use a speedometer cable (not digitally controlled)? That is the kind of noise I am hearing, but the speedo needle is steady.
No, the speedo's do not use a cable straight to the tranny, like the "old days".  It could be the wiring harness hitting on something causing your noise.
Good luck.
