Bilsteins and Hellwig
Habs
I'm wanting to put Bilstein 5100s and Hellwig front and rear sway bar on my truck. (2015 1500 4x4 CC SB)
Just wondering, since I have a 2.5" Rough Country level kit, 1.5" Zone body lift, 33" tires and 1.5" wheel spacers... will the shocks and sway bars be compatible with all the aftermarket mods? I'm clueless when it comes to suspension.
Thanks guys
Only issue I see is that if you adjust the 5100s you might need to remove the 2.5" level so not to over extend anything.
