NASCAR Funding Jesse Jackson
Firetiger(MN)
Humm.. Too bad. Shame on  NASCAR.  I will not waste my time on that sport anymore. In fact I am glad to see this.Ever since the King quit racing the sport has become a money hungry bunch of political crap.
If you want to see real racing , and real people go to your local drag strip or dirt track. Screw these over paid young punks! And the old farts who are running NASCAR!
Won't see me watching or attending another NASCAR event. I am so glad I did not re-new my Bristol,  and my KY speedway season tickets this year. To me , a lifetime NASCAR fan going back to JR. Johnson, King Petty, Davy Allison and Ernie Irvin, these new punks are just punks. I miss the sport when it was the southern boys racing cars  and was considered a redneck sport and not mainstream.  This is my last straw with NASCAR.
