More amps from 2015 in Cab power
ruggerag
Can anyone talk me out of this? I'm pretty disappointed in the weak usb and 110 outlets in this truck, they are pretty useless that my phone still runs down while plugged in. It looks like the outlets are 0.5 amp, so is there any reason I can't install another inverter, rum that to the 110 outlet, and then run 5v dc, 3a step-downs from the battery into the power lines on the usb ports?
Would I need to install a second battery with proper cutouts/switches?
The USB ports are useless for charging, I put an adapter in the power socket next to the USB hub.
Right, but I've got a $50,000 truck, it has usb "charging" ports, I want to make them work so I can use them... I don't want to just add some more gizmos and ignore the problem.
I guess I'll buy some parts this weekend and do some math. I was hoping someone had done this already, the big argument I've seen was that the wiring can't handle it and would melt, but the wires should be good up to a couple amps at least, depending on the specific size.
I think that's overkill. I have a 2.4a iphone car charger and it works as well as plugging in at home. Just pickup one of these and you'll be done. http://www.amazon.com/Maxboost-Portable-Compatible-Bluetooth-Extended/dp/B00ISGCDC6
I agree however that 5 USB outlets at 0.5a is pretty useless.
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 563 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
