Aftermarket projectors without HIDS
toms.abpg
I want to install anzo or some other aftermarker projector on my silverado, but i dont want HIDS. I read through every thread i could but every seems to add hids to these kits. Does anyone run halogen (stock) bulbs with projectors? I really just want the headlights for the led accenting.
I believe they come from the factory with halogen bulbs already installed
yes, but im not sure if the aftermarket projectors are as strong. If they are equilivent, that would be fine for me.
Ill know tomorrow. My new ltz look alike projectors arrive then. I plan on doing a comparo betwixt the halogen oem reflectors vs projectors with hid vs projectors without
Awesome, defiantly let us know please
I have the anzo's in my GMC and the projector is just fine. It's probably just as good as the oem projectors
Well ups just came and brought ONE headlight. Needless to say im pretty pissed, as the ad is clearly supposed to be for 2. Waiting on a response from seller. A couple things so far tho. They Are indeed Eagle Eyes brand. And so for, from initial inspection the one i have looks damn good. Ill know more about fitment when the other side shows up. Also the projector, itself is easily removeable from the rear which will be nice when i do my fxr retrofit. No baking should be required.
The gmc comes with projectors so why did you get aftermarket?
He probably wants the appearance of the anzos.
I have the spyders with the stock lights and I think I really need hids. The halogens aren't the best and may even be worse than stock reflectors.
just for the styling pretty much. i wanted a black headlight housing and didn't want to open up my headlights, so i went with the anzos
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 414 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
