Anyone have any experience with iBoards?
DRChevy
I've been looking at nerf bars and running boards for a few weeks now and I have narrowed it down to the 5" Silver iBoards as my favorite. Mostly for the price and appearance.
http://www.amazon.com/dp/B00WTKIYIO/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=31D8ZICCJWQ7Y&coliid=I3JB2ZCEVFTGTX
The only thing that is holding me back is that I never see them out on the road and I never see them mentioned on the forums. Is that just because they are new? Any advice would be very helpful. Thanks.
a guy at my work has them on his ram 2500 ......maybe its the truck being so big with a 2" lift kit and bigger tires than stock but they dont look very good on a truck imo
i had a set o the 3" on my '09 and loved them, the only issue I had with them was after about 8 months, the rubber they used on the tops for grip started to shift. that rubber is only held on by a few plastic rivets with double sided tape securing the rubber in the space between the rivets. If I didnt trade the truck in, I was gonna pull that rubber off and apply grip tape that they use on skate boards. Other than that I really like them, lus I wouldve went with the 4 or 5" boards...
  • 2 months later...
I like these, looking at getting a 4" wide set, and they're cheap enough to where I wouldn't be pissed if I had to retape the pad or something...
Anyway, I want to order a set, but in some pics it looks like they go all the way to the front of the fender, others look like they stop at the front edge of the door. I have a 2015 double cab and have the factory style splash guards, I want to make sure they'll fit behind the splash guards.
Thanks.
I had the factory splash guards on my '09 and they stopped about 2-3" from the splash guards, so you shouldnt have any issues there...
  • 1 month later...
I am actually very pleased with mine. I was a bit skeptical at first reading about them.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 912 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
