Hole in firewall
Skydiver504
I am finaly installing and wiring (hopefully) up my cubes and Lightbar. That being said, I am really hoping someone could tell me (and show me a picture) of where I can run a power wire through the firewall. I am really hoping to avoid drilling one.
It gets dark early so I am running out of time.
Best Regards,
Justin
Different application, but the same theory. I used a hole behind the distribution block under the dash. Comes out on the driver side top right corner of the engine firewall. Fast forward the video to about the 3:00 mark.
Good luck!
I hate going through the firewall so I went through the floor where your parking brake cable is.
Good luck!
Thank you so much! I was finished running all my wires through the firewall ten minutes after I watched your video! It was such a huge help!!
