Elite E2 Catch Can
Elite E2 Catch Can-$100 shipped free anywhere with Paypal payment. Will do local pickup also and located in Milwaukee WI.
CC is set up and plumbed for 2014 Silverado 6.2L mounted on washer fluid bolt. Literally ready to install in 5m flat. Selling as I upgraded to 3500.
Please PM
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
