Intellilink Startup Screen (Customize)
konjis1
Hi all, new here and just bought a 2014 GMC Sierra SLT. So far i love it and am sure i will feel the same way for some time! Anyways, i wanted to ask does anyone know if it is possible to customize the Intellink startup screen (add custom pics, etc)? If so, how do you go about doing so?
Thanks in advance and happy truckin!
