HISSING BUZZ SOUND - Please Help!
awilley17
Go to youtube and search for 2015 Silverado cabin filter replacement. I was trying to post a direct link to a video but for some reason it would not post.
I don't think that's the issue because the cabin filter is on the right side behind the glove compartment but the sound is emanating directly from behind the steering column/tachometer.
  • 1 month later...
Have you found any solution to this issue? I have it as well. I thought it might be the motor for the tachometer needle. I can't drive my truck without the window open or the radio up. It drives me nuts.
Sorry to say that I have not. Do you have a six or 8 cylinder? Have you taken your truck to the dealership. I can definitely second you on the whole driving me nuts thing.. I regret buying this truck and have considered trading it in for a used Dodge RAM. This purchase was somewhat impulsive.. didn't take my time and read about how many issues these generations of trucks are having. Problem is is I don't want to lose money so I think I'm stuck with it.
Yup v6 and same thing with me, an impulse buy. I have an appointment on wednesday at the dealer for numerous things including the radio making a loud bump then shutting off for a few seconds. Quality is garbage coming from 2 underpowered Tacomas. But everything on them worked great.
Let me know what they say and how it goes. I'm contemplating a 2015 F-150 now. They've got the best reviews and I test drove their 2.7 Eco boost.. the power is baffling for such a small engine. Also feel like the handling is smoother than the Silverados (which isn't to say the Silverado isn't already smooth handling) and the ride is much less stiff/bumpy.
Just an update: Scheduled an appointment for Feb 8th to have it looked at the same dealership I purchased from and the same dealership I have brought it to twice already. Talked to the guy who sold the truck to me who worked with me for a while and explained the whole situation to him.. told me he'll work with the guy in charge of servicing my Silverado.
If I get the same response of "oh it's a normal engine noise, its nothing" I'm going to consult with him and figure out what my next step is.. I need to be happy with my purchase.. I didn't commit to a 7 year loan with monthly payments to be pissed off every time that I drive my vehicle.
Yea dealer gave me the same runaround as I expected. "Everything is normal..." LOL it took them 6 hours to look into my minor complaints and update my radio software, what a joke. I did get into my foot wells with the doors closed(very difficult!) and it sounds like it may be an exhaust leak. I'm going to try and find out myself when I have time. There was a service bulletin on the 5.3 trucks with the exhaust not settling properly. Something to the effect of loosen everything and tighten it all back up in a set sequence. I may try this as a last resort.
Oh wow so they gave it back to you with no resolution on the noise? That's crap. I ended up having to cancel my appointment because something came up at work, so I'm rescheduled for Presidents day Feb 15th. I'll let you know asap what they say.
Have you considered taking your truck to a local auto shop that specializes in GM vehicles? They probably would be able to confirm or deny that it is an exhaust leak. An exhaust leak definitely matches the symptoms I have. If I can't get any recourse after they look at it a 3rd time that's probably what I'll end up doing. If they find something wrong with it I do believe the dealership would be obligated to reimburse you for any cost.
One of mine was making funny noise before the heat/air module went out. Does changing air flow positions make any difference in noise?
  • 2 months later...
A buzzing noise in my 2014 Silverado started yesterday. It's appearsbto be intermittent hearing it as I get into the truck. The first time I thought a bee or two followed me into the truck. Another time I just opened the driver side to to retrieve something from the door. The sound stops after 10 seconds or so, the truck has 30, 000 miles never had this noise before yesterday. If anyone has any ideas what it could be your response would be greatly appreciated.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 562 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
