2" front 1" rear installed with 33's.
Airwelldone
That's what I did to my truck, and I think it looks great. I now looks like how the truck should look. Used to look like there was a snow plow attached.
I totally agree it looks how it should look from the factory. Parked next to a stock 15 F150 yesterday. I sat pretty much level with it. Such a shame....
I have about 600 miles on the new tires and my "lifetime" mileage was 18.2 with a 50 miles best of 26.1. My last 600 miles have been about 65-75% hwy driving the sane route to and from work with a sub par 16.4 mpg. For sure a noticeable power difference with the heavier taller tires too. With the stockers, I could turn the nannys off and smash the throttle and the tires would roll smoke. Now if I smash it, I get maybe a couple rotations out of them. Ha.
Oh well, maybe that will allow me to get more miles out of these ones.
