Accessing the H16's for removal
Doug64
Hey guys, Does anyone have pics or vids on how to get to these fog light bulbs on a 14+ Silverado? When I tried, I couldn't even get my hand up there far enough. It's not nearly as easy as my 07 was.
The 1/2 ton 1500s are a piece of cake and easily accessable from underneath. It looks by your ur profile pic, that u have a 2500 and those are a different design, so i cant speak to that. If u are talking about the HD platform, u might have better luck under that forum
http://www.gm-trucks.com/forums/forum/174-2015-2016-chevrolet-silverado-gmc-sierra-25003500-hd/
This is a link to a youtube video for the 20151500. Hope it helps. Its not the best video. But when I changed mine out on my 2015 1500 it was very easy to access the bulbs from right under the truck.
