Goodyear not doing so good
RyanbabZ71
Just heard this morning goodyear isnt doing so good and laying alot of people off.
Another thing i heard was in the future car companys arent going to offer spare tires? WTF so if you get a flat your screwed?  ALl to save a few buck.
My guess would be that this is the result of Goodyear, making a deal with themanufacturers to boost their income.  Goodyear can make more money per tire by charging us everytime we need to get a spare than they charge GM for a bulk shipment for spares.  This brings in more $$$$ for Goodyear, and it drops the cost GM has to pay for tires, because they're buying one less per vehicle.
Unfortunately, these are the kind of business decsicions that we consumers have to live with and can't do much about.  :thumbs:
And howmany people who own trucks (excluding members to this board) would be able to actually change a wheel with the spare?  Every other damn truck has a woman driving it, which this is stereo typing but most have not one iota of a clue as to how to change a tire.  Heck, I've seen idiots run on flats, wondering why their vehicles wouldn't turn as well.... Loss for us yes, most no.
Maybe they will give each of us one of those Razor scooters that were the big hit of the show this year! :thumbs:
Cant ya just see that in the bed of everybodys truck?
I should knock on wood, but I have'nt had a flat tire the entire time I've been driving (18yrs).  I have ran nails into tires twice, once last spring with the truck I have now, but they were slow leaks and I drove them to a garage and had them plugged for 5 bucks.  Maybe spare tires won't be missed as bad as it sounds??  I don't know-I guess I'm glad I have a spare if just for peace of mind even if it never gets used.
I've never had a flat in one of my vehicles, although I did get a flat in Tom's old truck once. ???   But I like knowing that it's there if I need it.  Also the first time I bought tires for my truck when I used to have it, I just bought three and I kept the old one that was the best shape.  I used the spare and the three new ones, and put the old I kpet as a spare.  Saved some money there.  I would've done it with the Blazer, but I got bigger tires the first time I bought tires for it, rather than waiting a while like I did with my truck.
It's true that the industry may be going away from spare tires, but they're not just going to not give you any.  The references made in all the reports about fewer spare tires in the future is because most manufacturers will be going to "run-flat" or "extended-drive" systems.  When this happens you don't need a spare.  I wouldn't worry about getting a vehicle with 4 traditional tires and no spare -- it won't happen.  I just hope the traditional systems keep full-size spares and don't go to "donuts".
Scott
It's bad enough with the "temporary" spares they give you in cars but no spare tires?  This sounds like an idea Nasser came up with before he was ousted from Ford.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 575 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
